AmitR
Mar 23, 2018NETGEAR Employee Retired
Orbi MR 2.1 Update 3/23/18
Our teams are still working through the issues, but I wanted to provide a quick update on OrbiOS 2.1. We usually wait to release our software until it's available across all Orbi product lines, but ...
Gelissen
Apr 26, 2018Aspirant
Thank you very much :smileyhappy:
loomis1975
Apr 27, 2018Luminary
In related news, 2.1.3.4 was finally released for RBS50Y.
Is showing up in autoupgrade alongside 2.1.4 for RBR50/RBS50.
Or download at
https://kb.netgear.com/000056287/RBS50Y-Firmware-Version-2-1-3-4
- UlairiApr 27, 2018Luminary
Per this thread the update to 2.1.4.10 reinstated a previous problem that I had with both wired and WiFi download connection speeds being throttled by the RBR50 Router.
I previously overcame this by a factory reset after the last manual update to 2.1.3.4.. I'm really annoyed that it seems that I now have to go through a factory reset and a full set-up all over again - to get the full connection speed.
- DJPedroApr 28, 2018AspirantWhen I log into the Orbi app, the firmware update states that I have the latest firmware (2.1.2.18) - however when I log into routerlogin.net , a notification pops up that there is a firmware update!
Is this intentional, or is there an issue?- FURRYe38Apr 28, 2018Guru - Experienced User
You can download manually or use the web base router web page to update the FW. You'll be fine.
