AmitR
Mar 23, 2018NETGEAR Employee Retired
Orbi MR 2.1 Update 3/23/18
Our teams are still working through the issues, but I wanted to provide a quick update on OrbiOS 2.1. We usually wait to release our software until it's available across all Orbi product lines, but ...
Ulairi
Apr 27, 2018Luminary
Per this thread the update to 2.1.4.10 reinstated a previous problem that I had with both wired and WiFi download connection speeds being throttled by the RBR50 Router.
I previously overcame this by a factory reset after the last manual update to 2.1.3.4.. I'm really annoyed that it seems that I now have to go through a factory reset and a full set-up all over again - to get the full connection speed.
DJPedro
Apr 28, 2018Aspirant
When I log into the Orbi app, the firmware update states that I have the latest firmware (2.1.2.18) - however when I log into routerlogin.net , a notification pops up that there is a firmware update!
Is this intentional, or is there an issue?
- FURRYe38Apr 28, 2018Guru - Experienced User
You can download manually or use the web base router web page to update the FW. You'll be fine.
