AmitR
Mar 23, 2018NETGEAR Employee Retired
Orbi MR 2.1 Update 3/23/18
Our teams are still working through the issues, but I wanted to provide a quick update on OrbiOS 2.1. We usually wait to release our software until it's available across all Orbi product lines, but ...
leightonn
May 11, 2018Tutor
My system got auto-updated from v2.1.2.18 to v2.1.4.10 and I've been experiencing stability issues ever since. It would just drop wifi connection every few minutes. I tried resetting to factory default and that didn't help. I've also downgraded to 2.1.2.18 which was more stable but it has since auto-upgraded back to v2.1.4.10 although I turned off the auto-update feature via telnet.
Since I work from home, I need stable connection and this is driving me crazy! I previously used an ASUS Nighthawk R7000 and while it worked well I didn't have coverage in some areas of my two-story home (3000+ sq ft). Before the firmware updates, I was happy. Now I'm pretty close to ditching Orbi and trying Google Wifi or something else.
P.S. This is the second time I've had issues with firmware updates causing stability issues.
May 11, 2018Guru - Experienced User
Try this.
I would do a factory reset on the entire system and set up from scratch as well since your was updated from older FW.
