PDIGS44
Sep 08, 2016Aspirant
Orbi MU-MIMO Support
Hello. Is the MU-MIMO feature in the Orbi wireless system limited to the dedicated band between Router and Satellite only... or will the MU-MIMO feature also extend to devices that support MU... in a...
Irishbrowncoat
Feb 15, 2017Star
So I guess the question then is WHEN can this be turned on? I would love to be able to use Explicit Beamforming (tied directly to MU MIMO) however your present advice is dont use. Is there a timeline when this will be working?
MarkC1024
Feb 16, 2017Luminary
I've left Beamforming disabled and turn MU-MIMO on. I don't see why they would both need to be set the same.
