WarriorStrong99's avatar
Nov 30, 2021
Orbi Much Slower than Modem
Router Much Slower than Modem
Some quick information:
- 500mbps Internet plan
- ROUTER: Orbi RBR20 with 2 satellites near each other running at 50% transmission power (quite a small house).
- MODEM: Netgear CM1150v Docsis 3.1
- SWITCH: 8-port gigabit TP-Link (TL-SG108).
- Speed test done mainly through testmy.net
MODEM — no more than 38 feet cat 5e Ethernet —> ORBI ROUTER — pretty damn long cat5e cable, much longer than the one that connects the modem to the router —> SWITCH.
So I connected my computer to the modem directly and got around 480mbps each time. When I connect directly to the switch, which is connected to the Orbi router, I get 320mbps directly on the main router and roughly the same on the satellites (test done through PS5). Furthermore, WiFi drops me down to 120mbps.
What could be the issue? Is it normal to not get the same Ethernet speed when connected to a switch connected to the main Orbi router compared to directly to the modem?
Edit: I brought the Orbi router where the modem is and used a roughly 10 in shorter cat5e cable. I connected that to the Orbi router with that cable. I then connected the desktop computer with the same cable I used to connect it to the modem where I got 480mbps to the Orbi router. I got roughly 300 mbps so no change from before (actually speeds were worse lol).
Looking at the Orbi configurations:
- MU-MIMO = off
- Fast roaming = off
- Implicit beamforming = off
- Guest network = off
- 2.4ghz = auto
- 5ghz = somewhere in the 40s
I do have a smart home system with Zigbee being the main + a raspberry pi. The recent test with the computer directly linked to the Orbi router without the switch did not have the switch installed (zigbee system and such are all connected through there).
  • FURRYe38's avatar
    Netgear has set up a community forum specifically for the Orbi AC products. Most of the people who watch that forum are more likely to have experience with Orbi and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
    https://community.netgear.com/t5/Orbi/bd-p/Orbi
    https://community.netgear.com/t5/Orbi/Router-Ethernet-Much-Slower-than-Modem/m-p/2168684#M129085
    Thank you.
  • michaelkenward's avatar
    michaelkenward
    What do you get out of the router, before the switch? And with no switch on the network?
    I assume  that all tests are wired. (PS5 means nothing to me.)
    Maybe 120 Mbps is as fast as the wifi clients can handle. That's what determines wifi speeds.
    It might be worth a bit of background reading.
    Understand Wi-Fi 4/5/6 (802.11 n/ac/ad/ax)
    @duckware knows their stuff and can bust a few myths and cut through marketing hype.
    What firmware version do you have on the device?
    A number is more useful than "the latest". (It may not be by the time people read this.) There can also be newer versions, or "hot fixes", that do not show up if you check for new firmware in the browser interface.
    Feel free to consult the Orbi section. It  might offer a few more clues. But it is surprising, and a bit disappointing, that someone should tell you to do that without even trying to attempt some sort of  answer. Your questions are pretty generic and could crop up for any router.
    Router Ethernet Much Slower than Modem - NETGEAR Communities
    • WarriorStrong99's avatar
      WarriorStrong99
      michaelkenward No I know my test computer can handle the full 500mb because from what I wrote, I said that when I connect to the modem directly, I can get the full 500mbps. When I connected to the router directly (with and without the switch on the network) using 2 different ethernet cables for the switch to the modem and using the same patch cable that I used on the computer and the modem, I got around 300mbps which was the same on the PS5 (which is connected using ethernet to the sattlite Orbi).
      • Mikey94025's avatar
        Mikey94025
        Hero
        It looks like your modem is also a router: https://www.netgear.com/home/wifi/modems/cm1150v/ - It has multiple ethernet ports to support multiple downstream clients at once.  Can you put it into bridge mode?  Otherwise if you have Double NAT then that overhead can impact your speed.
        Alternatively, setup your RBR50 in Access Point (AP) mode and leave the router functionality to your CM1150V.
