kdeemer
Dec 29, 2017Tutor
Orbi multiple Mac Addresses
I have an ORBI router and two satellites. The router has MAC Address A0:04:60:22:1A:B2. I have a network scanner (fingbox) which every day reports a "Rogue Access Point" with the MAC address A6:04:60...
st_shaw
Dec 29, 2017Master
Sure. The Orbi RBR and RBS each have two mac addresses. Those starting in A6 are from the 2.4 GHz radios. Those starting in A0 are from the 5 GHz client radios.
At least that's how mine is.
- guzzijasonDec 29, 2017Apprentice
st_shaw wrote:Sure. The Orbi RBR and RBS each have two mac addresses. Those starting in A6 are from the 2.4 GHz radios. Those starting in A0 are from the 5 GHz client radios.
2 MAC addresses *per SSID*. If you use the guest network, that's 4 MAC adresses. If you count the hidden backhaul, that's 6 MAC addresses per device.
