ALNJ2017
May 17, 2017Star
Orbi multiple SSID
I would like a separate SSID for my home theater gear for simple security isolation.
- May 18, 2017
cant be done unless you use guest wifi for one and normal wifi for the other , but you cant have separate ssid names otherwise as thats how these systems work
peteytesting
May 18, 2017Hero
