KKCAUS
Jan 24, 2019Aspirant
Orbi NBN connection via Netcomm AC modem (Aussie Broadband FTTN NBN)
Appreciate any help to setup Orbi to connect to Aussie Broadband FTTN NBN via supplied Netcomm AC modem router. Understand that I can connect with Orbi setup in AP mode but read somewhere that I will...
raven_au
Jan 28, 2019Virtuoso
raven_au wrote:
KKCAUS wrote:
Are there any setup required at Orbi side besides setting it in router mode?
There shouldn't be.
I found this, not sure it's accurrate as I don't have the Netcomm.
https://support.netcommwireless.com/faq/nf10wv-bridge-mode-setup-guide
Also be aware that when the Netcomm is is bridge mode you'll no longer be able to use its VoIP so if you need phone services you'll need to get an Anolog Telephone Adapter (ATA) to connect your phone to the network. The Cisco ATA device that Aussie sells would be sufficient if you do need one.
Ian
raven_au
And one last thing.
In the Orbi all you should need to do is check the Orbi Internet settings are:
Internet requires login is set to no.
Internet IP Address is set to get dynamically from ISP.
Domain Name Server addresses is set to get automatially from ISP.
Router MAC address is set to use default address.
I'm pretty sure that these setting will be the defaults.
They were what I got when I setup the Orbi from scratch, I didn't need to change anything. Of course you need to connect the ethernet cable correctly, into the yellow internet port on the Orbi and into the correct port on the Netcomm (some routers want you to connect to a specific port when you set them to bridge mode), try port 1 on the Netcomm that's the most common one if there is a restriction.
Ian
