KKCAUS
Jan 24, 2019Aspirant
Orbi NBN connection via Netcomm AC modem (Aussie Broadband FTTN NBN)
Appreciate any help to setup Orbi to connect to Aussie Broadband FTTN NBN via supplied Netcomm AC modem router. Understand that I can connect with Orbi setup in AP mode but read somewhere that I will...
raven_au
Jan 29, 2019Virtuoso
KKCAUS wrote:
Thanks for the followup. Still pending Aussie Broadband reply.
I'd be interested to know how you go with this.
From discussions I've seen on Whirlpool AussieBB apparently have good support, something very rare these days.
KKCAUS
Feb 04, 2019Aspirant
Just to update. Aussie Broadband replied that they do not support bridging setup on th netcomm modem/router due to the complexity of the settings setup between devices. They adviced me to contact Netcomm directly for the help.
On the Netgear Orbi, they indicated that it should just require to be setup with a DHCP connection and where it says "Does my connection require a login" select No.
The access point setup with Orbi seem to be working ok so did not have a real need to play around with modem bridging yet.
