KKCAUS
Jan 24, 2019Aspirant
Orbi NBN connection via Netcomm AC modem (Aussie Broadband FTTN NBN)
Appreciate any help to setup Orbi to connect to Aussie Broadband FTTN NBN via supplied Netcomm AC modem router. Understand that I can connect with Orbi setup in AP mode but read somewhere that I will...
Feb 06, 2019Guru - Experienced User
If you set up DMZ on the modem correctly for the Orbi in router mode, yes this would be in a double NAT condition, however using DMZ on the modem helps to avoid double NAT problems with devices and applications that are connected thru the Orbi.
http://computer.howstuffworks.com/nat.htm
http://www.dslreports.com/shownews/Networking-101-The-DMZ-137550
