snybz
Aug 06, 2019Aspirant
Orbi Netgear GS908E-100PES Backhaul Connection
Hello, everybody, I have been using the Orbi Set (RBK23-100PES) for a few days now, i.e. router + 3x satellite. Because of reinforced concrete walls and underfloor heating, I only get a yellow sign...
- Aug 06, 2019
Yes. ANY IGMP protocols.
Test the RBS with out the switch in the mix. IF this works, then your problem will be the switch.
Aug 06, 2019Guru - Experienced User
Power OFF the ORbi system.
Disable ALL IGMP protocols ON the GS908E. Reboot if needed.
Power ON the Orbi system...report if this helps any...
- snybzAug 06, 2019Aspirant
Latest firmware on ORBI
So i have to deactivate IGMP Snooping? Or what do you mean by "protocols"?
Unfortunately, I haven't set anything up there yet.
