snybz
Aug 06, 2019Aspirant
Orbi Netgear GS908E-100PES Backhaul Connection
Hello, everybody, I have been using the Orbi Set (RBK23-100PES) for a few days now, i.e. router + 3x satellite. Because of reinforced concrete walls and underfloor heating, I only get a yellow sign...
- Aug 06, 2019
Yes. ANY IGMP protocols.
Test the RBS with out the switch in the mix. IF this works, then your problem will be the switch.
Aug 06, 2019Guru - Experienced User
Power OFF the ORbi system.
Disable ALL IGMP protocols ON the GS908E. Reboot if needed.
Power ON the Orbi system...report if this helps any...
snybz
Latest firmware on ORBI
So i have to deactivate IGMP Snooping? Or what do you mean by "protocols"?
Unfortunately, I haven't set anything up there yet.
- FURRYe38Aug 06, 2019Guru - Experienced User
