crowley213
Feb 04, 2021Follower
Orbi Netgear VPN solution possible?
At this moment I am using a RBR40 router with one RBS40 and one RBS20 satellite as my home network. In general it works great. On some of my devices (cell phones, tablets, computer) I am using Proto...
CrimpOn
Feb 04, 2021Guru - Experienced User
crowley213 wrote:As I understand, the RBR40 cannot act as VPN router.
This is correct. I am not aware of any Netgear router (Nighthawk or Orbi) that supports VPN "Client" mode.
crowley213 wrote:My idea would then be
- to connect the VPN router to the modem of my internet provider (wired) and
- the RBR40 to the VPN router (wired or wireless?)
Orbi routers must be wired from their WAN port to the internet device with an ethernet cable.
I believe this will work. Would imagine that it wll be most straightforward if the Orbi is put into access point (AP) mode so that the VPN router andles all the address translation. Disable WiFi on the VPN router.
