JVK1
Jun 18, 2020Tutor
Orbi network -- IP address conflicts (AC2200/RBK33)
Hello, I have several devices in my home using the Orbi router in both wired and wireless connections. For most of the wired devices – Tivo, AppleTV, Mac desktop – I've switched them to static IP ad...
Jun 18, 2020Guru - Experienced User
JVK1 wrote:Hello,
I have several devices in my home using the Orbi router in both wired and wireless connections. For most of the wired devices – Tivo, AppleTV, Mac desktop – I've switched them to static IP addresses because they kept having IP address conflicts; they work great now. However, sometimes with my wireless devices — iPhones, laptops, iPads — I get an IP address conflict. Usually after a device has left the Wifi network or had wifi switched off; I'll see an error message that says "Another device is using this IP address." I'll then have to wait until the router refreshes the DHCP lease and assigns a new IP address.
Is there something in the settings, possibly under 'Advanced', to force the router to expand the IP address range or else automatically apply a new IP address in case of a conflict? I have 16 devices in the house and only 6-7 are wireless -- there should be plenty of room in the IP allocation to handle everything, so how can I preemptively avoid these conflicts? I'm upgrading from my previous router (Spectrum Arri unit) which is now just the modem, but I never had this many IP address conflicts on the old equipment.
TIA,
JVK
That might be your issue right there. The old device not running properly in modem only/bridge mode.
What device specifically is it?
How have you setup the modem only mode?
- JVK1Jun 18, 2020Tutor
That might be your issue right there. The old device not running properly in modem only/bridge mode.What device specifically is it?
It's an ARRIS modem, DG1670. I still have the old Wifi network active so that I can go in there and change the settings, but it's definitely in Bridge mode otherwise I would be getting a bunch of rando IP addresses in the wrong range. Unless there's some advanced setting I'm unaware of, just turninig odd the router fucntion/putting it in bridge mode should be sufficient, no?
JVK
- CrimpOnJun 18, 2020Guru - Experienced User
It's an ARRIS modem, DG1670. I still have the old Wifi network active so that I can go in there and change the settings, but it's definitely in Bridge mode otherwise.....
When modems are in "bridge mode" they definitely do not broadcast WiFi.
- plemansJun 19, 2020Guru - Experienced User
Agree with CrimpOn If you have wireless running, its not in bridge mode.
So you'd be in a double nat.
https://kb.netgear.com/30186/What-is-Double-NAT
- FURRYe38Jun 19, 2020Guru - Experienced User
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
JVK
