JVK1
Jun 18, 2020Tutor
Orbi network -- IP address conflicts (AC2200/RBK33)
Hello, I have several devices in my home using the Orbi router in both wired and wireless connections. For most of the wired devices – Tivo, AppleTV, Mac desktop – I've switched them to static IP ad...
CrimpOn
Jun 18, 2020Guru - Experienced User
JVK1 wrote:
Is there something in the settings, possibly under 'Advanced', to force the router to expand the IP address range or else automatically apply a new IP address in case of a conflict? I have 16 devices in the house and only 6-7 are wireless -- there should be plenty of room in the IP allocation to handle everything, so how can I preemptively avoid these conflicts?
Yes, indeed. On the Orbi web interface, Advanced Tab, Setup, LAN Setup there are two features that might help:
- The Orbi's DHCP server can be configured to assign IP addresses from only a portion of the IP subnet.
For example, the Orbi could be set up to assign addresses from 2-99. Then you can use "static IP's" on devices from 100-250 (or the reverse). - Device "assignment" is what I use instead of static IP's. I put each device MAC address into the table along with the IP address I want it to have. That way, when I want to "move them around" I just change the table rather than logging into each device.
Orbi's IP assignment appears to have definite flaws. It seems to react to DHCP requests in a strange sequence. Devices contact the DHCP server and say, "can I have IP address 192.168.1.x?" and the Orbi says, "Sure, you had it before, go ahead." When what it SHOULD be doing is saying, "sorry, but no. the Boss says you have to use a different IP address from now on." My technique for forcing a device to change IP addresses when Orbi doesn't force it to is to (a) turn off the device, (b) haul out my old smartphone, (c) set it to a static address that I want the device to quit using, and then power on the device. It will ask for its old IP and the Orbi will say, "Sorry, that IP is in use right now. Here, take the IP that I find in this table."
Sorry to rave on.
- JVK1Jun 18, 2020Tutor
OMG thank you!! I thought I was going crazy. That totally sounds like what is happening.
I will definitely implement your suggestions and report back.
JVK
- JVK1Jun 19, 2020Tutor
CrimpOn wrote:Yes, indeed. On the Orbi web interface, Advanced Tab, Setup, LAN Setup there are two features that might help:
Hey CrimpOn, I definitely want to implement these options to see if it helps. So under LAN Setup, I would input a smaller IP address range under the "Use Router as DHCP server" checkbox, correct? And by "Device Assignment" do you mean the "Address Reservation" section at the bottom of that page? If so I should probably go ahead and add static IPs for all my wired devices, yes? Right now I only have two computers and a network printer in there but I've got other devices on the network like AppleTV, PS4, TiVo. etc.
Thanks,
JVK
- CrimpOnJun 19, 2020Guru - Experienced User
JVK1 wrote:
by "Device Assignment" do you mean the "Address Reservation" section at the bottom of that page? If so I should probably go ahead and add static IPs for all my wired devices, yes? Right now I only have two computers and a network printer in there but I've got other devices on the network like AppleTV, PS4, TiVo. etcYes, that is the place.
- FURRYe38Jun 21, 2020Guru - Experienced User
I would recommend doing the following for static IP addressed devices. Only set static IP addressed devices like printers, controllers, cameras and NAS to use static IP addressed devices. This is something I use in my configuration. Devices that don't need much or any router management, set static IPs. Other devices like phones, game consoles, PC and laptops and IoT devices which may need router management, use Dynamic IP addressesing with in the DHCP IP address pool. For static IP, yes these need to be outside of the dhcp IP address pool.
JVK1 wrote:
I definitely want to implement these options to see if it helps. So under LAN Setup, I would input a smaller IP address range under the "Use Router as DHCP server" checkbox, correct? And by "Device Assignment" do you mean the "Address Reservation" section at the bottom of that page? If so I should probably go ahead and add static IPs for all my wired devices, yes? Right now I only have two computers and a network printer in there but I've got other devices on the network like AppleTV, PS4, TiVo. etc.Thanks,
JVK
