Dumbus
Jan 20, 2021Aspirant
Orbi Network Apple Devices
Last week on Tuesday or Wednesday Hotmail login and Active directory login started being blocked on Apple Devices using the Orbi wifi network. It previously worked fine and still works fine if I do ...
- Feb 02, 2021
Dumbus wrote:I tried everything. Put Telstra Modem in bridge mode etc. Finally I found in the Orbi admin website (not on the Orbi App) that Disney Circle was enabled under the security tab. Turned it off and everything works again. Now I just need to find out why the Disney Circle App was blocking Microsoft websites suddenly. Thanks for your help
Nice
you may want to mark your post here as solved.
thank you
Dumbus
Firmware is 2.5.2.4. It is connected to Telstra NBN via a Telstra Smart Modem v2. I tried turning off Armor security and still had the problem connecting to Hotmail and Active Directory. I do not think circle is active but not sure as I do have the app.
Jan 20, 2021Guru - Experienced User
What mode is your modem working in? Modem or router? This modem has a built in router already. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
- DumbusJan 21, 2021Aspirant
Thanks for looking at this. I will review how the service and modem are setup over the weekend.
The main issue is this worked fine for several years and last week it stopped working. Something must have been changed last week? I use the Orbi app so assume the firmware updates are managed by this. The only thing I remember doing was enable the guest WiFi as the Orbi app advised me to do it to increase security.
- FURRYe38Jan 21, 2021Guru - Experienced User
Its best to use a web browser and log into the RBRs web page to do any management or FW updates from the RBRs web page.
Guest WiFi does not increase security. Guest WiFi is only for when you have guest visiting and you want to give then wifi access to the internet thru your system. Unless you have a constant need for Guest WiFI, I would keep Guest Network disabled.
- alokeprasadJan 22, 2021Mentor
I put all my IOT (security cameras, garage door opener, smart lights, smart TV's, Roomba etc) on the Guest network.
If the IOT device gets compromised (the cheap devices have buggy or insecure firmwares, almost never updated), then the devices are separate from my home network.
