Lorichs
Sep 15, 2019Aspirant
Orbi network doesn’t show up on computer
Hello. My family installed the orbi yesterday. Everything was and is working fine for everyone until now, abou 24 hours later, when suddenly the orbi doesn’t show up in the list of available networks ...
- Sep 15, 2019
Problem solved! I called the support desk. And yes, it was the hz that was wrong. Thanks for your reply.
Måns
ekhalil
Sep 15, 2019Master
Must be something wrong in the settings of the wifi adapter in your computer. Can you please check the wireless settings of the adapter, that the adapter accepts both 2.4 and 5 GHz bands.
Are you using Windows or MacOS,....?
What radio channels have you set in Orbi for 2.4 and 5 GHz bands?
- LorichsSep 15, 2019Aspirant
Måns
