MTPATL
Oct 25, 2019Aspirant
ORBI Network Dropping every 24hrs
Just recently installed an Orbi RBR50 in my house.I have AT&T Fiber, and after looking at suggestions online upgraded my AT&T Router to receive one with an IP Passthough. The AT&T moden was set up as...
SW_
Oct 25, 2019Prodigy
MTPATL wrote:Just recently installed an Orbi RBR50 in my house.I have AT&T Fiber, and after looking at suggestions online upgraded my AT&T Router to receive one with an IP Passthough. The AT&T moden was set up as a passthough and all antennas were shut off, using using the Orbi as the router.
The Network worked great for the first 24 hours and then dropped and i had to reset it. Apparently this happens everynight at the same time as my original set up.
Has anyone else experienced this, and if so, how do you fix it? I would hate to have to return the entire system, but its frustrating and unsustainable to constantly have to reboot the system every single night.
Any help would be appreciated.
I had Comcast Cable and had similar problem. The lease time on my Orbi IP was something like 3 days when I last checked when it was in Router Mode. I put the Orbi back in AP Mode to avoid this problem for now. Just posted a similar issue with the Satellite on a new thread.
- carladjMar 24, 2020AspirantI’m struggling with the same issue. Did you ever get it resolved?
Thanks for any help.
Carla- highwayMar 24, 2020Aspirant
CarlaI wish I could give you a miracle solution, but no :( Mine keeps loosing connection every day at the same time no matter what.
- FURRYe38Mar 24, 2020Guru - Experienced User
If the Orbi is loosing connections or network isn't working at regular time frames each day and specific times, and not a randsom time, this could point to a problem at the ISP modem or ISP service line up stream from the Orbi.
ALso could be some wifi interferences as well.
