MTPATL
Oct 25, 2019Aspirant
ORBI Network Dropping every 24hrs
Just recently installed an Orbi RBR50 in my house.I have AT&T Fiber, and after looking at suggestions online upgraded my AT&T Router to receive one with an IP Passthough. The AT&T moden was set up as...
Oct 25, 2019Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
MTPATL wrote:Just recently installed an Orbi RBR50 in my house.I have AT&T Fiber, and after looking at suggestions online upgraded my AT&T Router to receive one with an IP Passthough. The AT&T moden was set up as a passthough and all antennas were shut off, using using the Orbi as the router.
The Network worked great for the first 24 hours and then dropped and i had to reset it. Apparently this happens everynight at the same time as my original set up.
Has anyone else experienced this, and if so, how do you fix it? I would hate to have to return the entire system, but its frustrating and unsustainable to constantly have to reboot the system every single night.
Any help would be appreciated.
MTPATL
Oct 27, 2019Aspirant
Firmware is V2.5.0.38
My house is about 4500 square foot. The Router is on the main floor and i have a satelite in the basement as i have a few things that are connected to that via ehternet. It is more than 30 feet away, but the connection is good (when the internet is working of course)
In looking at the settings, the wireless AP is on. Assume that is different than AP Mode? Sorry, I am a novice at this!
- SW_Oct 27, 2019Prodigy
Click ADVANCED tab-> Advanced Setup -> Router / AP Mode. Check which radio button is selected.
Check out this how to set stqtic IP address link.
