ORBIisJUNK
Jun 07, 2020Aspirant
Orbi network drops frequently and Satellite showing poor backhaul status
Hi, I have following setup RBR50 - Setup in basement RBS50-1 - Setup on the first floor which is above basement RBS50-2 - Setup on the second floor I have 500Mbps fiber optics line coming ...
ORBIisJUNK
Jun 10, 2020Aspirant
Were you able to fix your problem? I did everything and nothing changed. It is hurting my WFH now. I moved my units and one of the Satellite still shows backhaul status poor. It is the same stellite which was showing poor earlier.
I am started getting frustrated now...
I will call NG support and update if I get something different from them.
denniss82
ORBIisJUNK
I ended up purchasing a different system, it was on clearance at Walmart for $74. Couldn’t wait anymore for Netgear to get they s..t together and fix what they messed up with the latest firmware update.
I sent a private message to a couple of people from Netgear on the forums, no one replied.
I set up the Linksys Velop system yesterday and it is running perfectly. Setup took about 15 minutes total for the three units.
https://brickseek.com/walmart-inventory-checker?sku=533132652
