seachellemz
Jul 30, 2019Aspirant
Orbi Network in Multiple Locations (residences)
I have two separate residences where I have a deployed an Orbi Mesh Network in each. My question is how can I remotely manage/administer each of them using the app. Does this require that I set up ...
seachellemz
Awesome...very helpful. One follow-up. I currently have both networks already set up. I am in residence-2 and have connected the Orbi app to it. I am no longer in residence-1, but the Orbi was set up prior to my leaving there. So....both networks are up and running. Is there a way I can gain access to residence-1 given that I am remote from it and did not follow the steps you outlined in your response.
ekhalil
Jul 30, 2019Master
Have you used the same app to setup both systems?
Have you registered both systems using the same netgear account?
Now that you’re at residence 2, open the app and select the home sign on the top left corner, then select "your products" in the row just under the top Orbi sign.
Do you see your products there?
To enable remote management using the app, go to Settings. In the app for every system and enable Remote Management.
- seachellemzJul 30, 2019Aspirant
Got it...thank you. One final question. Is there a way I can provide a unique name for each of those locations so that is what shows up in the list of my locations. Today it shows up as the Orbi names. I see that I can edit the router name in settings, but that is not the name that shows up in the list....it still just shows the default names of Orbixxx.
- ekhalilJul 31, 2019MasterI don’t think there’s a way to rename the systems to something that you can see in the app, unfortunately :(
