jarlag
Oct 13, 2021Follower
Orbi Network Map Not Showing Connected Devices
I have an Orbi 753 with 2 Satellites. Each sateliite used to show what devices were connected under the "Network Map" section of the Orbi app. Especially when the satellite had a "wired" item conne...
jieyin98
Oct 17, 2021Initiate
Orbi RB750 with 2 satellites - exactly the same issue, devices connected fine, but none show up in the network map, neither router nor satellites
- FURRYe38Oct 18, 2021Guru - Experienced User
Netgear has set up a community forum specifically for the Orbi AX (WiFi 6) products. Most of the people who watch that forum are more likely to have experience with Orbi AX and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-axFor Orbi app support, Netgear has set up a community forum specifically for the Orbi App product. Most of the people who watch that forum are more likely to have experience with Orbi App and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-App/bd-p/en-home-orbi-appThank you.
