jarih67
Sep 13, 2021Aspirant
Orbi network map shows only 3 out of 4 satellites
I have 4 Orbi Satellites in my RBK40 network but only 3 of them shows in the network map. If I close one of them, the forth will become visible. I will see all four if I click on the banner that says...
franktribe
Sep 13, 2021Apprentice
Mine only should the router and none of my 2 satellites in the Orbi app. On the web interface, everything looks fine. I think my router auto updated to 2.7.3.22. Because I never updated it. It was running great on the previous version I was on. Now, things are little off. Thinking of factory resetting or downgraded to previous one I was on (can't remember the version but, it was super stable).
Sep 13, 2021Guru - Experienced User
Try a factory reset and setup from scratch using a wired PC and web browser. Once setup, check orbi app. RBS should appear in the app.
