jarih67
Sep 13, 2021Aspirant
Orbi network map shows only 3 out of 4 satellites
I have 4 Orbi Satellites in my RBK40 network but only 3 of them shows in the network map. If I close one of them, the forth will become visible. I will see all four if I click on the banner that says...
Sep 13, 2021Guru - Experienced User
Do you have a screen capture that you can attached to a post here in the forums so we can see? Use the Choose File button.
Is this on the RBRs web page or Orbi app?
jarih67
Here is a screen shot. If I close one satellite, the hidden one will show in the map. I have two rbs40 and router rbr40 running firmware 2.7.3 22 and two plug-in satellites running firmware 2 6 2.6. The problem exists only in the app. In orbilogin i see all the satellites. Also in the app I'll see all the sarwllites when i click on the banner so i thought that the network map graphic can show only 2 satellites at the time.
