jarih67
Sep 13, 2021Aspirant
Orbi network map shows only 3 out of 4 satellites
I have 4 Orbi Satellites in my RBK40 network but only 3 of them shows in the network map. If I close one of them, the forth will become visible. I will see all four if I click on the banner that says...
jarih67
Here is a screen shot. If I close one satellite, the hidden one will show in the map. I have two rbs40 and router rbr40 running firmware 2.7.3 22 and two plug-in satellites running firmware 2 6 2.6. The problem exists only in the app. In orbilogin i see all the satellites. Also in the app I'll see all the sarwllites when i click on the banner so i thought that the network map graphic can show only 2 satellites at the time.
Sep 13, 2021Guru - Experienced User
Netgear has set up a community forum specifically for the Orbi App product. Most of the people who watch that forum are more likely to have experience with Orbi App and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-App/bd-p/en-home-orbi-app
Good Luck.
- franktribeSep 16, 2021Apprentice
FURRYe38 , I know you mention factor resetting a lot. I have done it once after an upgrade but most of mine I haven't had to reset. But, I think I might need to with this one.
When you reset it, do you manually reconfigure everything? Or do you back up the config and restore?
And finally, how do you feel about this firmware, good? Or is it worth waiting for another before going through all of this? Mine works...it's just "weird" sometimes. Like the Orbi app issues, and sometimes some devices have issues going to the internet, etc. But most of the time it works.
- FURRYe38Sep 16, 2021Guru - Experienced User
Ok sometimes a reset is needed.
You can back up the config then reset and restore. If you still see odd things, try a reset with out a restore and setup from scratch.
I didn't get enough time with my RBK50 to get a good feel of v22 before having to take it off line. I did see bad ethernet ARP storms when RBS were connected. I had to reboot both RBR and RBS and finally things settled down. I still had Circle and Parental Controls enabled after it was updated.
Might as CrimpOn on any experiences he has as he still uses the 50 series...
