abel358
Jan 22, 2021Aspirant
Orbi Network Map
I have an Orbi RBR20 with two satilites. Typical the network map on my phone app shows the two satilites connected in parallel to the main router. Recent the app shows the two satilites connected i...
Jan 22, 2021Guru - Experienced User
Its called daisy chaining. In some instances it does degrade performance but I've only noticed speeds slowing down at maximum speeds and not for general usage.
you can disable daisy chaining through the settings for it.
But you might find that it provides better speeds this route if its defaulting to that setup.
https://kb.netgear.com/000048458/What-is-daisy-chain-and-how-does-it-work-with-my-Orbi-WiFi-System
abel358
Jan 23, 2021Aspirant
Thank you for your feedback. I looked in my settings and do not see anywhere where I can disable daisy-chaining. Can you provide additional details where to look?
Thank you.
