abel358
Jan 22, 2021Aspirant
Orbi Network Map
I have an Orbi RBR20 with two satilites. Typical the network map on my phone app shows the two satilites connected in parallel to the main router. Recent the app shows the two satilites connected i...
abel358
Jan 23, 2021Aspirant
Thank you for your feedback. I looked in my settings and do not see anywhere where I can disable daisy-chaining. Can you provide additional details where to look?
Thank you.
vajim
Jan 23, 2021Master
abel358 wrote:Thank you for your feedback. I looked in my settings and do not see anywhere where I can disable daisy-chaining. Can you provide additional details where to look?
Thank you.
https://kb.netgear.com/000048460/How-do-I-disable-daisy-chain-topology-on-my-Orbi-WiFi-System
