abel358
Jan 22, 2021Aspirant
Orbi Network Map
I have an Orbi RBR20 with two satilites. Typical the network map on my phone app shows the two satilites connected in parallel to the main router. Recent the app shows the two satilites connected i...
Jan 23, 2021Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
abel358 wrote:I have an Orbi RBR20 with two satilites. Typical the network map on my phone app shows the two satilites connected in parallel to the main router. Recent the app shows the two satilites connected in series. That is, one satilite connected to the router and the 2nd satilite connected to the first satilite. What causes this and does it impact the performance of the system. How can I get it to go back to the way it was?
Thank you for your help.
