lamay11
Jan 05, 2020Aspirant
Orbi network not showing up
Hi all - I just returned home from the holidays to find that my Orbi router and satellites don't seem to work anymore. My modem still works, and I am accessing internet through that, but I cannot fin...
CrimpOn
Jan 05, 2020Guru - Experienced User
Could you clarify: the Orbi WiFi network name (SSID) does not appear on the list of available WiFi networks?
Do you have a laptop or desktop computer that can be connected to the Orbi with an ethernet cable?
When you restart the Orbi, what colors do you see on the power LED (on the back) and on the "Ring LED" (at the top)?
lamay11
Jan 06, 2020Aspirant
I tried to connect the laptop to the ethernet cable and there is still nothing.
The colors on the Orbi are green in back for the power LED and a pulsing white light for the ring LED.
- CrimpOnJan 06, 2020Guru - Experienced User
The pulsing white ring is not something one expects to see for a system that has been working for some time.
https://kb.netgear.com/31030/What-do-the-LEDs-on-my-Orbi-router-and-satellite-mean
My guess is it is time to get out the paperclip and perform a "factory reset" on the router.
Good Luck!
