Z190mn
Jan 05, 2020Tutor
orbi network turn of by dos attack
Hi, My orbi system turn off a view time's a week. When I take a look at the log file there is a dos attack standing on that time. I'm using: firmware version 2.3.5.30 orbi system RBR50 can s...
Spider4
Mar 26, 2020Aspirant
The netgear orbi router RBR50v2 is connected to Eurodocsis 3.0 modem.
I did factory reset of router and modem, to test the setup in orbi in router and dhcp mode.
The result is both negative.
Mar 26, 2020Guru - Experienced User
Where are these attacks coming from? Is the IP addresses a external address or an internal address?
Try downloading v30 FW on the RBR to see if this changes anything...
Spider4 wrote:The netgear orbi router RBR50v2 is connected to Eurodocsis 3.0 modem.
- Spider4Mar 26, 2020Aspirant
example: in DHCP mode
[DOS Attack: RST Scan] from 151.139.242.13, port 443 ......
[DOS Attack: ACK Scan] from 212.123.200.220, port 220 ......
example: in router mode
[DOS Attack: RST Scan] from 17.179.252.32, port 443 ......
sorry 2 typo's in the port; port is always 443
[DOS Attack: ACK Scan] from 212.123.200.220, port 443 ......
- FURRYe38Mar 26, 2020Guru - Experienced User
You might check those IPs with a whois web site.
Ask your ISP to give you a different WAN IP address to see if the attacks stop.
- Spider4Mar 31, 2020Aspirant
I have asked for the helpdesk for support and after a clean installation all works again.
