Jagan
Nov 24, 2017Aspirant
Orbi no internet after new ISP
Have no choice than writing about my issue here after trying everything. Switched to a new ISP yesterday since then internet is not working if I connect it through Orbi. Tired old Netgear WNDR4500v...
st_shaw
Nov 24, 2017Master
You said you changed to a new ISP and now both Orbi and your old router no longer work.
If you had Orbi and your old router setup to use a static IP from your old ISP, you might need to change your routers' settings to work with your new ISP.
I think you need to contact your ISP and ask them for help.
Jagan
Thanks for the advice yes I have raised a ticket with them as well. Old ISP assigned a static IP thats it they never asked me to change anything in the router settings like change the IP etc. It was just working as it is
Not really sure what is going on here even before the Static IP was assgined with my new ISP internet didnt work when they came for the installation first day as well. They gave a direct connectio to PC
So tested it with my old Netgear WNDR4500 it was same said no internet
