Hallc234
May 05, 2018Aspirant
Orbi No internet
Woke up today to no internet! Called Xfinity and they confirmed cable modem is getting signal and passing it thru ethernet cable to the orbi router. 3 backhaul wires from router to satelites are no...
Hallc234
May 13, 2018Aspirant
I had installed with router using wire connections to 2 satellites and then wireless from satellites to items. I had to disconnect the wires from router to satellites and reboot and then it worked. But when I plugged back in the wires it failed again. I am now running totally wireless but am finding I have to keep rebooting the router because it randomly just stops working.
Jgobble
May 14, 2018Tutor
This is what I am going through..
Almost daily reboots of the router unit. That (sometimes) doesn't fix it ... and I must reboot the SB6183 modem (via XFinity)...then reboot the router. Then it comes up.
The entire time this happens I can get to my hardwired mac mini from my wireless devices...just not the internet...by IP or by domain name.
FIX THIS!
- FURRYe38May 14, 2018Guru - Experienced User
Try a factory reset on both router and satellite and set up from scratch.
FIX THIS!
- JgobbleMay 14, 2018Tutor
This would be a good idea if I had not gone through almost an hour of entering all my MACADDR->STATIC IP mappings and done port forwarding changes too...
Do you mean do a factory reset and then re-upload my saved settings? Otherwise I just can’t see doing this...every time the orbi fails.
Just to see if from scratch fixes anything, then if so, try too apply a saved configuration from file.
