funkswing
Mar 30, 2022Aspirant
Orbi no longer broadcasts the default Wifi (ORBI) network after reset, unable to setup mesh router
My router has not been working properly after a power outage. It was broadcasting my custom network, but it was unable to connect to internet. I decided to reset the Orbi after trying a few other thi...
CrimpOn
Mar 30, 2022Guru - Experienced User
funkswing wrote:
After doing the reset (hold down the reset button for 10-15 sec)
The key part of doing a Factory Reset is to see the LED next to the power button change from green to amber, and then begin to flash. Until it starts flashing, it has not reset.
If power outages are a frequent occurrence, it might be a good investment to purchase a small UPS for the WiFi router. (I actually have the ISP modem, Orbi, and main Ethernet switch on a UPS.) Not to outlast a long outage, but to avoid the voltage surges that often accompany an outage and power restoration.
