funkswing
Mar 30, 2022Aspirant
Orbi no longer broadcasts the default Wifi (ORBI) network after reset, unable to setup mesh router
My router has not been working properly after a power outage. It was broadcasting my custom network, but it was unable to connect to internet. I decided to reset the Orbi after trying a few other thi...
funkswing
I was unaware you could connect via hardwire. All the instructions I found started with connecting to the ORBI** wifi network. How would I connect to the Orbi via hardwire (i.e. which domain/url/IP address to use)?
Mar 30, 2022Guru - Experienced User
You simply connect a pc/laptop via ethernet to one of the lan ports on the router.
If you've factory reset it, its default address should be 192.168.1.1 or you can try routerlogin . com
The power issues might have corrupted it and if the hardwiring it doesn't work, you can try recovering it.
You can try recovering it with tftp or nmrpflash.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
https://github.com/jclehner/nmrpflash
