gettyjoe
Aug 09, 2017Aspirant
Orbi not compatible with Netflix?
Netflix just won't work with the new Orbi. We're getting an error message stating that it looks like we're using an unblocker or VPN...we're not. The guy at Netflix told my wife that, in effect, Ne...
- Nov 28, 2021
Dacs wrote:
Hey! Thanks for replying.
My current set up is;
Model ORBI RBR50
Firmware V2.7.3.22
Virgin hub 3.0< The ISP modem you have has a built in router and wifi alredy. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopTry option #2 first....
st_shaw
Aug 09, 2017Master
Orbi works fine with Netflix for me. Do you maybe you have an old router still in use? Can you describe what equipment you have and how it's wired up?
- gettyjoeAug 10, 2017Aspirant
We had the Orbi hard wired into an Arris cable modem from our ISP. All the devices (Sony smart TV, 2 PC laptops, Chromebook, 3iPhones on wifi. Great signal and functionality with everything but Netflix. Took the Orbi off and put our Netgear Nighthawk (R7000) back in and Netflix was immeditely great.
FWIW, we could see Netflix on our devices, browse shows, etc. and it recognized us fine. But when we attempted to watch...error message.
