gettyjoe
Aug 09, 2017Aspirant
Orbi not compatible with Netflix?
Netflix just won't work with the new Orbi. We're getting an error message stating that it looks like we're using an unblocker or VPN...we're not. The guy at Netflix told my wife that, in effect, Ne...
- Nov 28, 2021
Dacs wrote:
Hey! Thanks for replying.
My current set up is;
Model ORBI RBR50
Firmware V2.7.3.22
Virgin hub 3.0< The ISP modem you have has a built in router and wifi alredy. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopTry option #2 first....
rhester72
Aug 10, 2017Virtuoso
Could also be that the switch to Orbi prompted a DHCP address change from the ISP, and the one the OP got just so happened to previously be assigned to someone who was known to run a relay like Tor. If that's the case, it'll expire on its own...eventually.
Netflix in particular is also VERY intolerant of IPv6 gateways like Hurricane Electric.
Rodney
cyberprashant
Aug 10, 2017Luminary
no problems here w charter cable for > 1 yr with orbi + netflix. (RBR50)
