gettyjoe
Aug 09, 2017Aspirant
Orbi not compatible with Netflix?
Netflix just won't work with the new Orbi. We're getting an error message stating that it looks like we're using an unblocker or VPN...we're not. The guy at Netflix told my wife that, in effect, Ne...
- Nov 28, 2021
Dacs wrote:
Hey! Thanks for replying.
My current set up is;
Model ORBI RBR50
Firmware V2.7.3.22
Virgin hub 3.0< The ISP modem you have has a built in router and wifi alredy. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopTry option #2 first....
bobthebuilder19
Dec 01, 2017Initiate
I went to http://orbilogin.net/QOS_wmm.htm and unselected wmm WMM: Wi-Fi Multimedia enhances quality of service on wireless LAN by prioritizing data packets
Seemed to fix the issue without having to roll back firmware.
- cyberprashantDec 24, 2017Luminary
i watch netflix all the time on Chromecast and sometimes on the dish network tuner netflix app - no issues. Make sure your router or satellite isn't too far from the device.
I have : everything default I didn't change the WMM. OpenDNS parental control (if you're using circle try disabling that?). Also turn OFF fast roaming but leave these checked
Enable Implicit BEAMFORMING - Boosts WiFi speed, reliability, & range for all mobile devices Enable MU-MIMO Try a chromecast they work great
