gettyjoe
Aug 09, 2017Aspirant
Orbi not compatible with Netflix?
Netflix just won't work with the new Orbi. We're getting an error message stating that it looks like we're using an unblocker or VPN...we're not. The guy at Netflix told my wife that, in effect, Ne...
- Nov 28, 2021
Dacs wrote:
Hey! Thanks for replying.
My current set up is;
Model ORBI RBR50
Firmware V2.7.3.22
Virgin hub 3.0< The ISP modem you have has a built in router and wifi alredy. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopTry option #2 first....
DudeDad
Dec 24, 2017Apprentice
Just set up my Orbi systems 3 weeks ago. No problem with Netflix both from wired devices ad wireless. Good luck!
- cyberprashantDec 25, 2017Luminary
Occasionally on my TV's built in app netflix hiccups - I think this is more a netflix issue. Try signing out of the app and back in. No problems on iPads, chromecasts, and netflix all sorts of different places and locations. Perhaps try a different wifi channel if you're in a congested wifi neighborhood. Try channel 1 or 11.
