gettyjoe
Aug 09, 2017Aspirant
Orbi not compatible with Netflix?
Netflix just won't work with the new Orbi. We're getting an error message stating that it looks like we're using an unblocker or VPN...we're not. The guy at Netflix told my wife that, in effect, Ne...
- Nov 28, 2021
Dacs wrote:
Hey! Thanks for replying.
My current set up is;
Model ORBI RBR50
Firmware V2.7.3.22
Virgin hub 3.0< The ISP modem you have has a built in router and wifi alredy. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopTry option #2 first....
Dacs
Nov 28, 2021Aspirant
Model ORBI RBR50
Firmware V2.7.3.22
Virgin hub 3.0
its a Samsung brand TV connected wirelssly.
signal tests is about 180mbps
the connections are fine and I can use Netflix normally. It's happened twice where I get a Netflix error that I'm using a vpn etc and suddenly I can only see global content.
it's happened to me once before and that was with a different router. A BT one.
Nov 28, 2021Guru - Experienced User
Model ORBI RBR50
Firmware V2.7.3.22
Couple of options,
- DacsNov 28, 2021Aspirant
Hey man!
I checked your links and saw that virgin hubs have a really simple way of switching to modem only mode.
it took 30 seconds to do and all our Netflix programmes have come back.
I can't thank you enough. Because of COVID my partner can't visit her family in the east and the dramas on Netflix have been a life line in keeping her connected to her culture.
samsung couldn't help. Virgin couldn't help. Netgear telephone staff couldn't help and Netflix could help. All of the, blamed the other person.
much happiness to you!
- FURRYe38Nov 28, 2021Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
Dacs wrote:
Hey man!
