Nwilliams625's avatar
Nwilliams625
Follower
Oct 08, 2017
Orbi not connected white light pulse only
I have 2 satellites connected at setup both worked fine. One was disconnected and when I tried reconnecting it just pulses white it won’t stop. I have tried hitting sync and have tried the reset button but it light still says at white pulse and app still shows only one of my satellites is connected.
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Have you tried to hold the reset button for 10+ seconds then try the sync again?
    DarrenM
