Gooobey
Jul 21, 2017Aspirant
Orbi not connecting devices to 5 gh
On my computer I have 5 Gh able network adapter. But while connecting to the Orbi i can not chose what band i connect to. This is very irritating. Im getting ready to retun the Orbi and buy a 150 ft ethernet cable.
hi
if your wireless adapter is dual band and it is within good range from the orbi router or sat it should automatically connect to the 5 gig
to check what its connected to open network and sharing center and click on the adapter status and see what speed it is connected at
if you are 150 feet from the orbi sat or router and there are a few walls in the way your never going to connect to any 5 gig
plz explain your setup and environment a bit better
- GooobeyAspirant
The Sat is one wall over from my room. I have a 5 gh capable device. I have connected to the 5 Gh channel before. When i unplug the wireless adapter it connects to the 2.4 channel and i can not force it to the 5 gh channel.
i dont understand the second part of that sentance , when you unplug the wireless adapter how does it work at all ?
