Gooobey
Jul 21, 2017Aspirant
Orbi not connecting devices to 5 gh
On my computer I have 5 Gh able network adapter. But while connecting to the Orbi i can not chose what band i connect to. This is very irritating. Im getting ready to retun the Orbi and buy a 150 ft ...
Gooobey
Could you guide me in a direction for me to do this?
martyfp
Jul 22, 2017Luminary
I did the following:
- on the PC open the "device manager"
- In the device manager, open the list of "Network Adapters"
- One item in your list will be your WIFI adapter
- Right click on the adapter, and select "properties"
- Select the "advanced" tab and you will have a list of the properties that you can change.
- The exact list will depend on the wifi adapter that you have in your PC,
- My laptop has a selection for "preferred band" which I set to 5GHz.
- My desktop has something called "wireless mode" that I set to 802.11ac
- Your setup will likely have something different, but browsing through the options should reveal one which forces it to 5GHz
I hope that helps.
For me, both machines are working just great on 5GHz where they appeared to randomly switch between 2.4 and 5 previously.
