AutomatedHome94
Nov 15, 2018Follower
Orbi not connecting to Smart Home Devices (wemo, ring, zmodo)
We just bought an ORBI.
House: Townhouse, 3 levels, main modem/router is on middle floor with a satelite in each room.
From mobile phones, ipads, and laptops the connection strength, and spe...
Nov 16, 2018Guru - Experienced User
What FW is currently loaded?
Is the Orbi system operating in Router or AP mode? .
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
What WPA security modes are you using?
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually.
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop or https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point
