Markjwood37
May 16, 2019Follower
Orbi not connecting
Please help , have connected the Orbi to my modem and ran the setup but it keeps saying no internet connect , I am using the app to do this on my iphone , I am currently with Slingshot in NZ and , the phone brings up the WIFI fine but thats it .
1 Reply
Is the Orbi system operating in Router or AP mode?Did you power OFF the ISP Modem then back on before turning ON the Orbi?
Modem Combo Units:
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ or IP Pass-Through for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
