Robbyt69
Nov 24, 2020Aspirant
Orbi not displaying all connected devices
Ok I’m on Firmware version 2.5.2.4 on my router and all satellites and I have a problem where many of the drives on network do not show up, either on the app or through the admin console under attache...
Dec 01, 2020Guru - Experienced User
Any progress on this?
FYI:
Robbyt69 wrote:
Ok I’m on Firmware version 2.5.2.4 on my router and all satellites and I have a problem where many of the drives on network do not show up, either on the app or through the admin console under attached devices.
All the devices in question have IP addresses assigned and are working, so I can’t figure it out. It’s like it’s filtering out some of them, and this is mixed between wired and wireless connections.
flipflop49
Dec 05, 2020Aspirant
I believe that you may have ipv6 enabled on those devices that are connected to the Orbi but do not seem to show up on the Orbi's "Attached Devices" list. If you disable ipv6 in the individual device's settings, reboot the device and then refresh the Orbi's "Attached Devices" list it will show up.
FURRYe38 wrote:Any progress on this?
FYI:
