mrjordan's avatar
Sep 19, 2020
"Orbi Not Found" Orbi RBK30-100NAS
My Orbi app says "Orbi Not Found" and won't complete the app setup process....but the network itself is functioning correctly. Full speed. Default firmware as of an hour ago. I don't have access to that info right now because the app won't finish setting up.
  • FURRYe38's avatar
    Try a setup with a ethernet connected PC or laptop and a web browser pointed at 192.168.1.1 or orbilogin.net.
    • mrjordan's avatar
      mrjordan
      Tutor
      Ah there we go, router firmware is V1.8.0.4.
      App running on iOS 14, getting 160Mbps down on my PC connected to the Orbi network, which is the expected (improved) speed. The app just isn't recognizing the Orbi router for some reason. I haven't changed the SSID. One sattellite unit.
      • Mstrbig's avatar
        Mstrbig
        Master
        Go to:
        https://www.netgear.com/support/download/
        and download the firmware starting with the oldes one. I'm not sure what order you need to update, but it is probably firmware related, as your firmware is old. Latest is 2.5.1.16
