beyondfedup
Oct 04, 2022Follower
Orbi Not Found
I had to do a factory reset on my Orbi CBR40. I am trying to set it up via the Orbi app. I get through the entire thing and then it says that the Orbi is not found. All of the lights on the front are ...
Oct 04, 2022Guru - Experienced User
Did the phone change it's wifi to connect to the new SSID from the CBR during the setup routine?
I recommend setting up the CBR using a wired PC and web browser connected to 192.168.0.1 or orbilogin.com
