bobselff
Dec 31, 2018Aspirant
Orbi not giving full bandwidth -Orbi AC3000
Need some help please as I'm at a loss. I have internet with 350 megs. When I test the internet speed using the orbi app it shows 320-350 which is perfect. When I connect my Ipad and run a test in th...
Dec 31, 2018Guru - Experienced User
What FW is currently loaded?
Is the Orbi system operating in Router or AP mode?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
What WPA security modes are you using? Try WPA2 and AES only.
Depending upon the iPad, it may only be able to test at 100Mb. IF other devices are testing good an the iPad isn't, possible issue with the iPad.
What iOS are you using on the iPad?
What generation model# is the iPad?
Orbi app is being used on which device?
Do wired PC speeds work?
bobselff
Router Firmware Version V2.2.1.210
Modem: Netgear CM600
Operating as: Router
Home Size: 1900 sqf
Distance about 25-30 feet
Channels: Auto
Neighbors: 5
WPA - WPA2
Orbi App - Phone and Ipad
You were correct on the ipad, only goes to 100. I tried my phone downstairs and its at 300+.(Playstation Downstairs)
My main concern was my sons playstation. I was using the ipad to test. It seems wired or wireless his speeds fluctuate from 30-135.Connections to the satelltes show good.
