KyroElite
Dec 23, 2018Aspirant
ORbi Not lettign me go to certain sites
Hello, my family recently purchased an orbi and although we get better speeds it blocks us from some sites, asking for a username and password. I have tried entering "admin" and "password" which does...
- Dec 23, 2018
You can probably start by setting Orbi in AP mode. If that solves the problem then you know that the issue is in the IP network.
Please login to orbilogin.com and do the following setting:
KyroElite
How would I go about doing that?
ekhalil
Dec 23, 2018Master
- KyroEliteDec 23, 2018Aspirant
That's part of the issue, I get the same login error when trying to connect to orbilogin.com. I also tried entering the ip, to no avail
- ekhalilDec 23, 2018Master
Please connect a PC by LAN cable to the router and login.
If that doesn’t work with the ISP router connected then please try with ISP router disconnected.
Which IP addresses are your devices getting? This will tell us if they are coming from Orbi or ISP router.
- KyroEliteDec 24, 2018Aspirant
I am currently directly connected to one of the satellites, to no avail. When I checked ipconfig this is what I got:
Ethernet adapter Ethernet:
Connection-specific DNS Suffix . :
Link-local IPv6 Address . . . . . : fe80::71e0:9b11:e1b8:2740%6
IPv4 Address. . . . . . . . . . . : 10.0.0.12
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 10.0.0.1EDIT: not sure why this posted twice
