KyroElite's avatar
KyroElite
ORbi Not lettign me go to certain sites
Hello, my family recently purchased an orbi and although we get better speeds it blocks us from some sites, asking for a username and password. I have tried entering "admin" and "password" which does...
  • ekhalil's avatar
    ekhalil
    Dec 23, 2018
    You can probably start by setting Orbi in AP mode. If that solves the problem then you know that the issue is in the IP network.
    Please login to orbilogin.com and do the following setting:
